First post, by iVirtualZero
Every time i try to install XP i get a Blue Screen of Death. Why am i getting these errors? I’ve tried to install multiple times with another cd, harddrive, ide cable and same issue. I get this error when i format the harddrive and then run the setup.
Reply 3 of 32, by iVirtualZero
Thanks looks like it installed but now i get Disk Boot Failure Insert System Disk and Press Enter.
Reply 5 of 32, by iVirtualZero
kolderman wrote on 2020-05-22, 01:00:
iVirtualZero wrote on 2020-05-22, 00:55:
Is your bios set to boot from C first?
No CD Rom. I’ll change it to HDD. But unfortunately it’s way past my bedtime.
Reply 7 of 32, by iVirtualZero
I changed it to HDD and same issue.
Reply 9 of 32, by kixs
What is your system config?
From your last screenshot it can't be seen if you have master hdd installed. Maybe some cable got disconnected.
Reply 10 of 32, by darry
What mainboard and controller are you using ? Your boot screenshot indicates you have an integrated IDE controller and some other controller . Depending one which one your disk is connected to, you may need to select something other than C in BIOS . if using an IDE controller from Promise or one like it , you would need to select SCSI as a boot option (even if the card is not SCSI, the BIOS just sees it that way).
Reply 11 of 32, by iVirtualZero
darry wrote on 2020-05-22, 11:28:
I’m using a Epox EP-D3VA. I’ll have good look in the bios may have to reset it. I’ve changed the IDE cables with some new ones.
Reply 12 of 32, by iVirtualZero
My HDD is connected to IDE Port 1 and set to master.
Reply 13 of 32, by iVirtualZero
kixs wrote on 2020-05-22, 11:24:
Yes my bios see’s my harddrive but upon boot nothing happens. I’ve changed over the IDE cables and will see if it makes a difference.
Reply 14 of 32, by iVirtualZero
Guess i’m probably just stuck with Windows 98 wanted a dual boot XP system.
Reply 17 of 32, by darry
If setting to SCSI worked, that means your drive is connected to a HightPoint HPT366 controller on your motherboard, not the VIA standard IDE controller integrated into your board's south bridge .
Glad it worked .
EDIT : I am actually a bit surprised it did not get 0x7B BSOD since, as far as I know XP does not come with HPT366 drivers (requiring the F6 option to provide a driver diskette) . At least, I don't think the original RTM release did . Then again, if ithe installer did manage to find a drive to install to, it must have had proper drivers (maybe later XP releases did) .
Reply 18 of 32, by iVirtualZero
darry wrote on 2020-05-22, 14:34:
Glad it worked .
Hmm that’s weird because it says IDE1 on the port. I installed XP Pro Service Pack 3 i think it is a later release backup. What is a HPT-366 controller for? I have a dual cpu socket 370 motherboard unlike the Socket 370 Asus one i had before this has support for less ram, 4 ide ports and an ISA port.
Epox D3VA
https://www.anandtech.com/show/816/8
Reply 19 of 32, by darry
iVirtualZero wrote on 2020-05-22, 14:42:
Hmm that’s weird because it says IDE1 on the port. What is a HPT-366 controller for? I have a dual cpu socket 370 motherboard u […]
Glad it worked .
Hmm that’s weird because it says IDE1 on the port. What is a HPT-366 controller for? I have a dual cpu socket 370 motherboard unlike the Asus one i had before this has support for less ram, 4 ide ports and an ISA port.
Epox D3VA
It provides extra IDE ports, in this case faster ATA100 ones compared to the VIA ATA66 ones .
According to the manual, the 2 HPT366 controlled IDE ports are the blue ones on the photo (black on some board revision) by the RAM slots . The manual says they should be labelled 3 and 4 . They might be labelled differently on your board (would not be the first time a manual is not 100% accurate).
    epd3va.pdf
    4.03 MiB
    46 downloads
