First post, by Spitz
- Member
Hi.
So there goes my another retro PC. This time I've got some old Intel Pentium I i75mhz icomp 610 sx969 paired with FIC PA-2010+ mobo and here it begins having problem setting correct mhz for this CPU. While reading manual it gives me info that by shorting certain pins I can get FSB 50mhz and ratio 1,5x that's fine.. =75mhz BUT looking at the mobo instruction on PCB it saiz that by shorting the same pins ... I'll get FSB 55MHz (???) with ratio 1,5x it will give me 82,5Mhz .... What's more - there isn't even option for 50Mhz on the mobo...
Any suggestions/tips ?
Thanks in advance!
Well... I miss 80/90s ... End of story
