Keatah wrote on 2020-05-25, 10:06:
How can I go about creating a bootable CF card for use with XT-IDE or similar interfaces? I'm familiar with the typical imaging programs and RMPREP, Rufus, and others, as well as working with Winimage and HDDGuru RawCopy.
Hi. I'd also try it on the real hardware first. In case no floppy drive is working on the target PC,
XTIDE BIOS can also be forced to boot from serial port (requires running host program on another PC and a null-modem cable).
Alternatively, you can also try setting up an HDD in an emulator. Like 86Box/PCem.
Just configure it accordingly to match your target PC (say IBM PC, XT-IDE etc) and install DOS to the HDD image.
Afterwards, run Win32DiskImager, open the image and write it onto your CF card.
Edit: In case you encounter lots of trouble, you might also consider giving DOS 7.x or FreeDOS a try.
If memory serves, these are LBA aware or do at least have a more modern boot loader.
MS-DOS 6.2x usually can handle HDDs up to 8GB in capacity only.
If the HDD in question is bigger, DOS 6.2x -or rather its FDISK program- might behave strangely.
Edit: Another program you can try is "HP USB Disk Storage Format Tool".
It's meant for USB pen drives, but maybe it will also work with an USB CF card reader..
