First post, by CachoAlpuy
I have a bios dump made by NSSI which size is 64KB.
If i edit the rom and write it back with Uniflash, will it work (assuming the change in the rom is ok) or will en error or something happen?
What i want to do is bypass the cpuid check in the bios of a socket 7 motherboard.
