mt777 wrote on 2020-06-09, 21:29:
I have a few questions which couldn't find clear infos.
1) P90 runs with FSB 42MHz. Is possible to run stable with higher cpus (for example with P100?) Which VLB cards can handle ~50MHz ?
Yes. The Nx586 P100 runs at 93 MHz and the board does support it.
That produces VL-Bus at 46.5 MHz which is passable, but many VGA cards will need to add a waitstate reducing performance somewhat.
However, it is less problematic than VL-Bus on 486 DX-50 for example. This is because NexGen VL-Bus cards are not directly connected to CPU local bus, like on 486, but the signalling on VESA slots is facilitated by the chipset.
2) PF100 - I read that PCI version supports PF cpus. Maybe does exist some kind of hack to run with on VL version too?
I don't know about any such hack.
