esbardu wrote on 2020-06-11, 15:09:
So the question is, is it worth to use a K6-2 instead a Pentium III, why are Super Socket 7 mainboards so appreciated?
To answer your question, specific Super Socket 7 mainboards that support K6 "plus" CPUs are very appreciated when paired with a K6-2/3+.
That's because these CPUs can be used as a sort of time machine, due to some unique capabilities (like the ability to change the CPU speed in software, disabling L1 cache while leaving L2 cache activated).
Because of this, you can progressively slow the CPU down to 386 / 486 speeds, which will allow you to play most speed sensitive DOS/early Windows games, while also being able to comfortably play more demanding games from 1998/1999 or even 2000 (depending on the game).
This is something that you can't really do with any other CPU/platform. For example, a Pentium MMX gives you a more granular level of slowdown control, however this CPU can struggle even with some late DOS games (not to mention games from 1998/1999 which are virtually unplayable)
But, I think that for many people, a Pentium 3 Coppermine/Tualatin is probably more suitable. It will still allow you to play many DOS games (and late DOS games will be blazing fast), while also being much more powerul than the slow SS7 CPUs, allowing you to play at high framerates most games up to 2000/2001.
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
