First post, by Cga.8086
hi guys
when it comes to test real pc memory we normally use MEMtest under DOS.
but what can i use to test video card memory under DOS?
i was given a small bag full of chips like these ones, and i plan on testing each with an old videocard like this one that has sockets
Reply 1 of 8, by canthearu
If your card has VBE 2.0, then the video memory test from Heron's boot CD works fine for testing video memory.
Reply 2 of 8, by Horun
Yes Hiren Boot CD has some good tests. Being that is a PCI am guessing you need something that works on a some what older machine like Hirens BootCD 12 or 13. You could also look for Video Memory Stress Test 1.7.116 (Windows Freeware) or Video Memory Stress Test CE 1.21 (Dos Freeware).
Here is a link to similar question here at Vogons you should read: Testing VRAM on older cards under DOS?
Video Memory Stress Test 1.7.116 : https://www.majorgeeks.com/files/details/vide … tress_test.html
Reply 3 of 8, by b_w
Which DOS memory test tool exist to test conventional memory (and XMS, EMS possibly) for PCs before 80386 CPU - 8088/86, 80186, 80286 that will fit on 360K floppy disk?
Reply 4 of 8, by darry
Cga.8086 wrote on 2020-06-14, 01:57:
hi guys when it comes to test real pc memory we normally use MEMtest under DOS. […]
hi guys
I could be wrong about this, but I have doubts about the durability of that socket to the multiple mating (insertion) cycles that will be required for testing a bag full of chips .
For example, according to this manufacturer, https://web.archive.org/web/20200201101517/ht … wtb_ic_plcc.pdf , their PLCC sockets are rated for 25 mating cycles .
EDIT : These https://www.mouser.com/catalog/specsheets/gs-12-158.pdf are rated for 25 mating cycles as well.
EDIT2 : These https://www.farnell.com/datasheets/217369.pdf are rated for 50 cycles .
EDIT3 : I just realized that I answered a post from last year . Oups .
Reply 5 of 8, by konc
b_w wrote on 2021-07-15, 03:37:
Checkit comes to mind
Reply 6 of 8, by maksg
The best memory test for MSDOS, I have ever used is <Speedsys>.The only problem is that it requires 386. For 8086-80286, the best option is <Check-it 3.0> (you can find it on winworldpc website)
Reply 7 of 8, by weedeewee
maksg wrote on 2023-04-16, 16:25:
Please remove the link you just posted, otherwise moderators will do it for you.
Do not ask Why !
Reply 8 of 8, by maksg
done
