First post, by bofh.fromhell
So a lot of graphics cards was brought home.
And theese fellas were found in the box:
They belong on a GF2 Ultra so i kinda want to make it work.
But since identifying SMD stuff seems to be a black art I need your help!
I'm assuming the "330" is the capacitance, they measure about 300 uF
But the rest?
Only similar size caps I have are marked:
251
330
6z
But I'm guessing I wont be lucky this time.
Reply 1 of 4, by Horun
330MF 6.3v. Here is a pic of some Sanyo SVPC 6.3V 330UF SMD that have nearly identical markings..
    16.1 KiB
Reply 2 of 4, by bofh.fromhell
Horun wrote on 2020-06-14, 19:20:
Looks pretty similar!
Now I wonder if the letter "E" has any significance, I'd bet it has or it wouldn't be there.
Reply 3 of 4, by Horun
Probably a ripple current rating, since it is on a video card it would be like one in a switching PSU or board VRM and be high current/low ESR. Just about any good capacitor should work though. If you know which video card it came from it would help.
Reply 4 of 4, by bofh.fromhell
If going by this pic found on the eevblog forums:
https://www.eevblog.com/forum/beginners/need- … ng-a-capacitor/
I should be fine using the caps I already have.
Or at the very least the spec wont be so far away as to damage anything.
