First post, by jakethompson1
- Oldbie
I have an AOpen AX4SG-UN. This board has an onboard Ethernet port with RTL8139. When connected to Ethernet it will only stay connected for a few seconds and then claims it's disconnected. I've had some luck forcing it to 100 Mbps full duplex and maintaining a connection.
What could have caused this, perhaps a power surge on the ethernet port at some point in its life? Any ideas on a fix besides manually configuring the mode? All 8 contacts appear to be in good condition inside the port.
