First post, by vacatedboat
Hi i have had this system for 20yrs and decided to give it some tlc. The power supply is full of dust. I have ordered a new cmos battery as well. My questions are about co processor. Must i get one the same speed as cpu eg dx40? Not sure if i can find one. Also question about ram simms. I have found 4mb simms fpm 30pin Hyundai but not sure about taking the purchase risk. I am unable to locate motherboard details online. Many thanks
508.53 KiB
378.26 KiB
Sorry had to split the image
Reply 1 of 16, by evasive
Yeah you'd need a 40MHz part. I think it will say so in the manual. When the system boots, it will show an ID string at the bottom of the screen. An example of an AMI BIOS id:
51-0102-1101-00111111-101094-AMIS123-P
You can use the pause/break key to keep it on the screen to make a photo (or write it down). With that we maybe can find who made the motherboard.
Reply 2 of 16, by NScaleTransitModels
This board looks a lot like yours: https://stason.org/TULARC/pc/motherboards/M/M … 486-386-AD.html
For the SIMMs, make sure they are also parity ie. they have either 3 or 9 chips, not 2 or 8. And also rated for 60ns ideally.
Builds:
  • ECS FX-3000; 386DX-40@50; ET4000AX, ISA 1mb
  • Acer VI9; 486DLC-40; Mach32, VLB 2mb
  • Chicony CH-471A; CX486s-40; Mach32, VLB 2mb
  • Gateway 2000 P5-60; Pentium-60@66; S3 928, PCI 3mb
  • DTK PKM-0033S; AM5x86-133@160
Reply 3 of 16, by evasive
The naming of the front panel connectors is different but other than that it seems to be matching. 😀 Maybe a relabeled board. We'll know when we get a bios ID string.
Reply 5 of 16, by Anonymous Coward
Some 386 motherboards can run the FPU in async mode (slower or faster than CPU), but it it only works with intel FPUs. Your board doesn't appear to have a second oscillator socket, so it appears you'll have to get one at the same speed as the CPU. Just about any 40MHz 387 should work fine. Cyrix is supposed to be the best, but you probably wouldn't notice unless you ran specific benchmarks.
Reply 6 of 16, by cyclone3d
A 33Mhz FPU will most likely run just fine at 40Mhz. They are generally a bit easier / cheaper to find than the 40Mhz labeled ones though I do see some 40Mhz listed in eBay right now.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 8 of 16, by vacatedboat
Thanks for all the helpful responses. I dont plan to power up again until i change/clean battery and refurb power supply. Yes i forgot about the parity stuff on simms and will try to post a pic of bios page. The hyundi ram on ebay stated 4M x 9 70ns. When looking at the chips i already have they are 60ns. No rush on it. I will wait until a 40mhz 387 fpu comes up i can afford and get that. From a screen capture the cache is 128kb but i may invest in more. Found 4 x windbond chips identical on ebay.
Thanks
Reply 9 of 16, by Anonymous Coward
cyclone3d wrote on 2020-06-23, 15:11:
Most of them probably work okay. I wouldn't want to overclock an old Cyrix 83S87 though. Around 1992 cyrix moved to the "387+" core due to troubles with the older core at 40MHz.
Reply 10 of 16, by Pierre32
This is the case for me. Asus ISA-386C mobo, 386DX/40 CPU, i387DX/33 copro.
Reply 11 of 16, by vacatedboat
Just an update. I got the bios number. Hope this helps in identifying the motherboard.
Im just waiting for 128kb cache and 387 copro i ordered.
I gave it a complete clean and refurb the power supply too.
May i ask the coprocessors have a 68pin but my MB have a few more holes and not sure how to orientate the chip once i get it. Many thanks
Also is the 16bit opera web browser still the best to use for the system?
Many thanks
676.22 KiB
Reply 12 of 16, by Horun
vacatedboat wrote on 2020-07-12, 22:14:
Just an update. I got the bios number. Hope this helps in identifying the motherboard. Im just waiting for 128kb cache and 387 […]
Ok The board has marking for Cyrix 387 68 pin and Weitek W3167 which is 121 pins so your board supports both. Better to use the Cyrix or a ULSI 387. It will use just the inner two rings of pins (think of it like a 486 in a ODP socket). Pin one is labeled on the board so you should have no issue getting it installed proper, just double check before you apply power 😀
Added: a Cyrix 33Mhz 387 should work fine (since that was the fastest they made before changing name to Reveal 387).
Bad news it the BIOS string is for 1374 which WimsBios has no entry for the manufacture, iirc there was someone here with same bios string and they figured it out.
Reply 14 of 16, by Horun
vacatedboat wrote on 2020-07-13, 03:07:
Thanks fortunately i ordered the ULSI chip.
I will do a search for a similar bios string snd have a read
Great ! the ULSI 387 is a good chip ! Good luck on your search as I came up empty so far.
Reply 15 of 16, by Anonymous Coward
Uh, Cyrix sold tonnes of 40MHz 387s under their own name. Reveal was a separate company that rebadged products from many different vendors.
Reply 16 of 16, by vacatedboat
The new 128kb cache memory came. Installed and changed jumper setting. It feels a bit zippy on windows. Is there a dos command where i can see how much cache i have. It no longer displays at startup. Want to make sureits 256kb.
Hope its ok to keep posting or should i make a new thread?
