First post, by dries_86
I have a Dell Optiplex GX1 which upon pushing the power button sometimes does not POST.
Basically there is no video and no beeps. Power LED is on though and CPU fan running and also every second there is an endlessly repeating blinking LED from CD-ROM drive & NIC.
At that moment the computer can't be turned off by holding the power button for 5 sec. I noticed if I hold Reset + Power for 5 sec sometimes it turns off.
The workaround for the issue is pulling the power cable and plugging it back in. The computer then starts and usually POSTs.
The configuration:
Dell 88865 Optiplex GX1 motherboard
Pentium II 350 Mhz Slot 1 CPU
64 MB SDRAM
Build in ATI Rage Pro Turbo AGP
Dell HP 145-SNH Power Supply
40 GB IDE HD, IDE CD-ROM, Floppy
ISA Riser board
Things I've tried:
- changed all BIOS settings
- upgraded BIOS to A10
- tried different RAM sticks
- swapped the PSU
- Removed all additional things like HD, CD-ROM, Floppy, ISA riser board, extra VRAM module.
- When I remove the CPU or memory I get beeping
I'm afraid the motherboard might be broken. Could it perhaps be related to the caps (they are visually in good shape/flat) ?
I think I did in the past but could try swapping the CMOS battery however do not think it might be related as the computer is keeping the BIOS settings without power.
A new Slot 1 CPU will arrive this week so I can test with another CPU but I doubt the issue is the CPU.
I added 2 photos.
Any ideas ?
