First post, by Oetker
- Oldbie
I'm researching a Tualatin upgrade for a 440BX system. I discovered that my VRM goes low enough, however not in .025v increments. I'm also led to believe this won't be an issue - looking at VRM specs, an older VRM will just provide 1.45v when queried for 1.475, and that I can always set the slotket to request 1.5v (which the processor should be able to take). Is that correct?
However, am I correct in understanding that the lower voltage, and resulting higher current, could mean the motherboard's traces can't take it and/or that the MOSFETs will overheat? Are there MOSFET specs I can check for this? Mine do have a heatsink attached, but will that be enough?
I've calculated that with a 32W TDP CPU, I'd be running 16 amps with Katmai, 18 with Coppermine but 22 with Tualatin, so quite a big jump.
