OPL2 LPT
First post, by Mark_81
Hi guys
I've found this https://www.serdashop.com/OPL2LPT
What exactly is it?it's a sound card for the parallel port?
I'm very interesting into FM Synth music generated from YAmaha YM3812
At the moment I use opl2/3 DosBox emulator on My modern PC
I'm looking for someting better..I have not the chance to buy Real ISA Adlib
Do you think this is good?
Reply 1 of 2, by Deksor
Yes. It's been documented quite well by YouTubers in the recent years. I think the owner of this shop is from vogons too
Reply 2 of 2, by Mark_81
Deksor
Thank you for your interest
I've you are not Busy, I would like to explain you my situation
I've only 1 computer station
OS Windows 10 Pro 64 bit v.2004
CPU Intel I5 7400 3GHZ
RAM 16 GB
MoBo ASRock B250M PRO4
Scheda Video NVIDIA GeForce GTX 1050 Ti
Scheda Audio Realtek High Definition driver RTKVHD64.sys v 6.0.1.7936
I'm looking for someting better...Emulators cannot be accurate like Real Hardware...I've seen many videos comparing Real OPL2/R chip with emulators
It's obvious i cannot purchase a SBPRO/16 and insert in my Mobo because its doeans's support ISA..Also i would have to install SB drivers ecc...
What are thae options that I have?
To config a new retro PC?new Mobo/New CPU ecc
Or what can I do?
