First post, by AngelRF
Hi to all, recently I updated my 486, from Windows 3.1 to Windows for Workgroups 3.11, because I wanted network support. My mouse is a Microsoft/IBM compatible from Commodore.
I updated using the normal setup, installing on the same directory of windows 3.1. When I rebooted the mouse was not working.
I tried to replace the drivers using the DOS windows setup, and it sometimes worked. Last time it solved using Logitech driver, weird.
Yesterday was working with the Logitech driver, and this morning it was not (I tried to use Microsoft's and Logitch's drivers, even Genie's one, and replacing those with the setup, none of it worked anymore). I didn't do anything between I turned off yesterday and booting today, I'm tired of this, and I already tried to reinstall windows a couple of times.
Do anyone could help me, or have the same issue? It will be very appreciated. Thanks for listening to me.
