First post, by SodaSuccubus
- Member
Though I had my 486 build done. Guess not 😜
Pressing the turbo button crashes the machine. I thought maybe it was some kind of sleep mode, but unpressing the button does not restore the PC. My turbo button is a 3 pin, and the header on my DataExpert exp4044 is a 2 pin. Iv tried different position with the pins to no avail.
I don't think the turbo jumpers are broken. Way way back when I first got the board I hooked up a two pin push button and it worked fine.
I'm using a DX4 Overdrive. I have it jumpers for a DX33 (as I think you where suppose to do for ODPRs) although the board does have its own jumpers for a DX4. If that matters.
