First post, by joshwa
I have an old Pentium 150 CPU lying around, and I've bought an S7 motherboard for it.
However, there is one pin that has snapped off the CPU - it is directly opposite and furthest away from the alignment corner (not sure what it's called). So, does anyone know if this missing PIN is actually needed? I read that there might be spare pins on these?
Thanks
Josh
Reply 1 of 2, by kixs
Here is the pinout:
https://flylib.com/books/4/57/1/html/2/images/03fig18.jpg
It looks there are spare VSS around and it should work fine.
