First post, by hiczok
The fan spins up on boot but then stops.
It's the pentium II 450 cartridge build.
Any idea what software I can use?
hiczok wrote on 2020-07-24, 21:26:The fan spins up on boot but then stops.
It's the pentium II 450 cartridge build.Any idea what software I can use?
Have you checked the BIOS setup for a hardware monitor/control page/section ?
It is not uncommon for some systems to rev fans to full speed at boot just to test them, though completely stopping a fan on a P2 seems odd to me . If you put it under some load, does it spin up ?
Software-wise, Speedfan and SIV come to mind .
Speedfan should be able to read rpms and temps
