First post, by TelamonLivesOn
Hey all, I recently just built a Socket 7 System with a Pentium MMX 166 and 64mb EDO RAM. I am also using an Adaptec 2940 u/uw PCI SCSI controller for both the 32x CD-ROM (50-pin) and 4.3gb HDD (68-pin). Each of them are properly terminated via jumpers/cable terminator. However, whenever using a Windows 95 boot disk that supports this controller (loads the CD-ROM driver), I cannot read/write to the HDD (for some reason, I can still detect the drive if fdisk was run without the driver loaded). However, this is ONLY the case whenever the drivers ASPI8DOS.SYS and ASPICD.SYS are loaded (not loading them allows the card to properly function). I have configured the controller to use its onboard bios, support Large Hard Disks, and support Int13H extensions. Also, the CD-ROM reads fine whenever the driver is loaded. Any help would be appreciated!
Here is my configuration:
Config.sys:
device=himem.sys /testmem:off
device=ASPI8DOS.SYS
device=ASPICD.SYS /D:MSCD001
Autoexec.bat:
LH A:\MSCDEX.EXE /D:MSCD001
NOTE: The case is exactly as stated in the files.
EDIT: When running Windows 95 Setup from the CD-ROM, it says that "Windows Setup requires 740032 bytes available on your C: Drive."
