One step forward...a leisurely jog backwards. Sorry for prolonging this, but I'm stuck anew at the PSU wiring. So, I did a voltage test on the "new" ATX, and everything looks swell (though I ended up getting a newer one that didn't have a -5v in the tester, but I'm not 100% sure my AT/ATX adapter even has a -5v, and I'm reasonable sure from reading around vogons that none of the equipment I have needs -5v anyway.)
But in the old AT PSU, the HDD power wire comes down to a plastic 4pin m/f connector and then goes up to the HDD. That's fine, but in addition to the four main wires, there are a couple of thinner two wire split offs from each side of the connector that run to the separate CPU heatsink and the Mhz readout on the case. Photos attached. Basically they powered a couple other things from the HDD power line. But there is obviously nothing quite like this coming off the newer ATX, just a pair of 4 pin connections.
My main question is: am I going to have to rewire this if I want to power the heatsink / case readout with the ATX PSU? If yes - and this will show my vast inexperience here - is there an easy way to pry apart each of the plastic connectors (not the m/f from each other - that's easy, I mean open each of the plastic cases to expose the ends of the wires) so that I can just add the existing pair of offshoots into the (opened) ATX plastic sleeve, basically just mirroring what is in there now? Well, it wouldn't be exactly the same, since I would have to run BOTH pairs into a single 4 pin (which maybe wouldn't work?). Or would I have to cut the wires at the plastic and redo the whole connection?
Hope this is relatively clear - I'm sure there are names for things that I'm getting wrong. First two photos are from the AT, the third is from the ATX (though I'm sure that one is familiar to everyone on here already.)
