Turn on AT PSU without Motherboard
First post, by Mephusto
Like the title says, I was wondering if anyone here can tell me how to turn on an AT PSU without a mobo attached so I can check it for voltages with a multimeter? Also if you have any insight into how to check and what to look for I would greatly appreciate it. Thank you! Oh and looking inside, the caps and stuff loom alright to me.
Edited to add a sentence.
Reply 1 of 25, by quicknick
You'll need to provide a minimum load, else it won't start or the voltages will be all over the place. I keep a couple of dead HDDs (that are still spinning) for this purpose. The voltages might still be a bit off with such a light load, but at least you'll know if it's safe to use it to power a full system before a final voltage check.
Reply 4 of 25, by Mephusto
jakethompson1 wrote on 2020-08-24, 01:40:
Assuming yours is the type with the power switch on a thick black cable, it will turn on immediately when you press it.
Okay. Yeah mine has a thick black cable that goes to the front of the case to a big switch. Thanks so much. I have to work for the next few days, but when I get it tested I will be sure to get on and update everyone on how it's doing. I'm really hoping it runs well so I can get am authentic dos early 90s experience. Nothing wrong with dosbox, it really works well, but I never got the real experience back in the day. Too poor 🤷🏼‍♂️
Reply 5 of 25, by gdjacobs
Mephusto wrote on 2020-08-24, 01:51:
Careful with AT PSUs as that cord to the front carries mains voltage.
Reply 6 of 25, by InbetweenDays
gdjacobs wrote on 2020-08-25, 06:15:
I'll second this too.
Off at the wall, power cable unplugged both ends.
Turn PSU switch on. Move it somewhere safe.
Plug power cable into PSU, then wall.
Turn on at wall.
At least, that's what I'm trying to always do, even for the fully heatshrinked switches. I've been zapped a couple of times and that was when being careful too.
The only way, if you have to do it at all, is to not touch that switch when the PSU is plugged in.
It don't mean a thing if it ain't got 5-pin DIN.
Roland addict and founding member of the Association Of Molex Haters
Reply 7 of 25, by mockingbird
There do exist AT PSUs with a power switch on the back instead of cords that carry to the front. Why this is, I don't know. But I have one and use it myself to test motherboards with AT power connectors.
(Decommissioned:)
Reply 8 of 25, by gdjacobs
mockingbird wrote on 2020-08-25, 14:23:
Early generation machines. Front power switches are way more convenient, so they quickly became the standard.
Reply 9 of 25, by Mephusto
Thanks so much! I didn't know that and I probably would have gotten zapped. I never would have thought they'd have mains voltage on them. I'm off the next 2 days and I am planning on working on testing them out
Reply 10 of 25, by Miphee
Mephusto wrote on 2020-08-26, 04:46:
Use insulating tape on the wire contacts to avoid accidental touching.
Reply 12 of 25, by Miphee
Mephusto wrote on 2020-08-26, 05:52:
Yeah I will. I usually dont mess around anything that is still connected to an outlet or with large capacitors. Electricity is very respected by me.....I'm scared of it.
You can also bypass the PSU rocker switch with a single switch adapter, that way you don't have to touch the PSU at all. Just switch it on and use the adapter's switch to turn it on/off.
Reply 13 of 25, by Mephusto
Miphee wrote on 2020-08-26, 06:13:
well thats cool I didn't think of looking for something like that. Are the old AT power supply switches that bad?
Reply 14 of 25, by Miphee
Mephusto wrote on 2020-08-26, 13:58:
Not at all but it's unsafe when it's outside the PC case.
The bare contacts are often visible, the cable lugs may become loose so you have a chance to accidentally touch them and get electrocuted.
So you either use insulating tape to cover the contacts or use a separate switch and don't touch the PSU at all.
Reply 15 of 25, by Vaudane
quicknick wrote on 2020-08-24, 01:15:
This is something I have toyed with for actually building an AT power tester. 50-100W resistors are cheap. What sort of loads would be required on each rail for a decent power tester? Do you just gun it at max power output as this should be specified on the PSU somewhere? Do you use high resistances to measure the voltage accurately, but that gives low load? Obviously overloading with low resistances is a bad idea as once the magic smoke gets out, you can't put it back in...
Reply 16 of 25, by Oetker
I've noticed that sometimes AT PSU power buttons have four wires, sometimes two. Isn't a two-wire switch rather unsafe as, depending on how the user's outlet might be wired, it could only be switching neutral?
Reply 18 of 25, by Miphee
imi wrote on 2020-08-26, 18:12:
I don't recall ever having seen one that only has two, got an example for that?
if it does it probably has some internal startup circuit.
The one I posted is a converter cable from China, haven't seen a single-pole switch on a regular PSU either.
