Vaudane wrote:
What sort of loads would be required on each rail for a decent power tester?
My guess would be switchable banks of resistors, to be able to load the main rails up to their rated current. And maybe some fixed 0.3A loads for the minor rails.
Resistors can be overloaded quite a lot if you provide forced airflow, and for that purpose you can use computer fans supplied from the very PSU being tested.
Oetker wrote:
I've noticed that sometimes AT PSU power buttons have four wires, sometimes two. Isn't a two-wire switch rather unsafe as, depending on how the user's outlet might be wired, it could only be switching neutral?
Haven't seen one with two wires, but I wouldn't rule out their existence. Most newer ATX power supplies have a single pole switch on their backs, and in countries that use non-polarized outlets this means in about 50% of cases you're switching the neutral (yeah, I know, nobody switches the ATX power from the back, but still). Shouldn't be dangerous, unless you start poking the insides while plugged, and that's a bad idea regardless if the switch is single pole or 2-pole.
