Reply 1 of 6, by Vaudane
- Member
HP maintain an index of most of their old software. You can find it here:
ftp://ftp.hp.com/pub/softpaq/
As for that individual system, I don't know what one you need.
Reply 2 of 6, by implozja
Thank you, but
I am looking for a disc which enables to install instal bios for this computer on a new disc.
Reply 3 of 6, by andrea
I've found this:
http://pcrebuilding.altervista.org/1/18/TECHN … iagnostics.html
SP4711 for a single plane motherboard and SP15674 for a split voltage machine
Reply 4 of 6, by implozja
andrea wrote on 2020-09-08, 09:48:SP4711 for a single plane motherboard and SP15674 for a split voltage machine
Thank you a lot.
Can you elaborate how can I discover which michine I own?
Reply 5 of 6, by andrea
implozja wrote on 2020-09-11, 10:37:andrea wrote on 2020-09-08, 09:48:SP4711 for a single plane motherboard and SP15674 for a split voltage machine
Thank you a lot.
What's the board part number? Should be written near the memory slots in a form such as XXXXXX-XXX (all numbers).
Or as a crude but often right rule of thumb, what CPU does it have? If it's a MMX* then it's split voltage motherboard, if it's an older MMX-less Pentium then it's single voltage.
*Excluding later diy upgrades, 2.8V MMXs will fit and work in a 3.3V board, even if you aren't supposed to so such a thing.
Reply 6 of 6, by implozja
Thank you. I discovered that I have Pentium 166 without MMX. I succesfully installed and configured new hard drive. Thank you again for help.
