First post, by implozja
Hello,
I am looking for recovery disc for Compaq Deskpro DP 2000 series 3563v5.
I am looking for a disc which enables to install instal bios for this computer on a new disc.
Thank you for your help
Reply 4 of 6, by implozja
andrea wrote on 2020-09-08, 09:48:
SP4711 for a single plane motherboard and SP15674 for a split voltage machine
Thank you a lot.
Can you elaborate how can I discover which michine I own?
Reply 5 of 6, by andrea
implozja wrote on 2020-09-11, 10:37:
Thank you a lot.
What's the board part number? Should be written near the memory slots in a form such as XXXXXX-XXX (all numbers).
Or as a crude but often right rule of thumb, what CPU does it have? If it's a MMX* then it's split voltage motherboard, if it's an older MMX-less Pentium then it's single voltage.
*Excluding later diy upgrades, 2.8V MMXs will fit and work in a 3.3V board, even if you aren't supposed to so such a thing.
