First post, by CaelThunderwing
Anyone happen to know where or how i can obtain a replacement I/O Shield for this old MB?
Photos? Shields are fairly cross-compatible, if one has the same overall layout of ports it will likely work.
kolderman wrote on 2020-09-07, 22:10:Photos? Shields are fairly cross-compatible, if one has the same overall layout of ports it will likely work.
mind the dust, compressed air can i guess got used up when cleaning out my 486 n main PC,
Thats very standard, 90% of shields from the late 90s will fit that board, even if you have to tape up a couple of empty holes at the bottom.
