First post, by DeckardGames
Greetings everyone
Recently got an MSI ms-6168 which, as you can see, needs some work.
Some caps need replacing, missing heatsink on northbridge, missing heatsink and fan on the voodoo chipset, bios is missing, etc.
I've been reading some stuff: MSI MS-6168 ... is a rebirth possible ? and understand that there's two bios available for this.
Before I start repariring other stuff, I'm in doubt on wich bios to use. Award or AMI? Also, can I just write an eeprom with the bios? If so, what kind of chip should I use?
Thank you!
Note: The board does get power.
Reply 1 of 14, by PD2JK
https://de.msi.com/Motherboard/support/MS6168
In the .exe I concluded the following:
The board uses an Award BIOS.
It needs an DIP-32 EPROM from SST or Winbond with a capacity of 256kB (2Mbit / 2048kbit)
The northbridge doesn't need a heatsink per se, but is nice to have. The Voodoo of course, needs to be cooled. Originally it had a heatsink with a fan.
If you create enough airflow, you could stick a larger heatsink on it. It's a shame there aren't any holes around the chip, then you could use something like a Zalman NB47J. Now you have to thermal-glue a heatsink on it. 🙁
Hope the VRAM on that board is okay! Nice project. 😀
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 2 of 14, by dionb
AMI and Award. The retail BIOS is AMI, the Award BIOS is Packard Bell OEM.
You have slightly more options in the retail BIOS, but some things from the PB Award BIOS aren't in there. Overall, I've not found a pressing reason to use one or the other. Do go for latest version of either for best CPU support.
Here's the latest retail BIOS I could find:
http://vogonsdrivers.com/getfile.php?fileid=1 … menustate=29,28
As for burning - it's a 2Mb (256kB) image so you need (at least) a 2Mb EEPROM. All the usual suspects should work, when in doubt, just grab a chip from a dead board of similar age and re-use. I have both images flashed onto two chips and swap them out whenever I feel the urge.
Replace the two bad caps, put a heatsink+fan on the Voodoo (it gets *really* hot and there are no mounting holes for the heatsink 🙁 ) and burn a BIOS and you should be good to go. If you want to feel happy, add a low passive heatsink on the 82443BX northbridge, but unlike the Voodoo that's not necessary (unless you want to OC to 133MHz FSB, which I've never gotten stable...)
Reply 3 of 14, by DeckardGames
dionb wrote on 2020-09-15, 10:53:
AMI and Award. The retail BIOS is AMI, the Award BIOS is Packard Bell OEM. […]
I can use one from another mobo? I've tried, but I have to tell the programer which chip I'm using and i honestly don't know.
Reply 4 of 14, by dionb
DeckardGames wrote on 2020-09-15, 11:27:
Look on the top of the chip, it's normally written there.
Reply 5 of 14, by Deksor
I don't think you can use a bios from another board if that's what you mean, because the bios here must be containing the voodoo 3 bios.
For the chip however you can definitely use one from another board. You can try to guess the type of ROM, check the id (which will probably fail but will report you the rom's id) and then search for a rom with this id.
Or you can pull off the sticker on the EPROM.
Reply 6 of 14, by DeckardGames
dionb wrote on 2020-09-15, 11:39:
Ahh, I've found one from another mobo. A AT29C010A and I got this on my programer's software.
I think I can say the bios is written. I guess.
Of course nothing happens with the machine 🙁
Reply 7 of 14, by DeckardGames
PD2JK wrote on 2020-09-15, 10:11:
https://de.msi.com/Motherboard/support/MS6168 […]
I have some thermal "stickers" also from zalman which I can use for that.
Reply 8 of 14, by dionb
DeckardGames wrote on 2020-09-15, 12:13:
Ahh, I've found one from another mobo. A AT29C010A and I got this on my programer's software. I think I can say the bios is writ […]
29C010A is a 1Mb (128kB) EEPROM, so no way will a 2Mb image fit on it.
Reply 9 of 14, by DeckardGames
dionb wrote on 2020-09-15, 13:09:
Crap. Looking for more.
Reply 10 of 14, by DeckardGames
Have six donors but, according to google, they're all 128k.
Would something like this do? https://www.ebay.co.uk/itm/Ti-TMS27C020-12-25 … EEAAOSw-v5eMAGs
Those recognized by my programmer.
Reply 11 of 14, by dionb
DeckardGames wrote on 2020-09-15, 13:29:
Would something like this do? https://www.ebay.co.uk/itm/Atmel-AT28C256-15P … mAAAOSwcp9ezkfB
Edit:
That's a 28dip. Nevermind
It's also 256kb, not 256kB. Don't mess up bits and Bytes with these things 😮
Look for something like the Winbond W29C020C instead.
Reply 12 of 14, by DeckardGames
dionb wrote on 2020-09-15, 14:28:
Edit:
Found these:
90B - https://www.ebay.co.uk/itm/W29C020C-90B-INTEG … BkAAOSwX61ZDIHT
90Z - https://www.ebay.co.uk/itm/W29C020C-90Z-WINBO … xQAAOSwpDdU7c3B
UV - https://www.ebay.co.uk/itm/Ti-TMS27C020-12-25 … EEAAOSw-v5eMAGs
Reply 13 of 14, by dionb
Steep prices, but the 90Z looks decent. Don't do the UV unless you have a UV chip eraser handy...
Check whether your programmer supports it though...
Reply 14 of 14, by DeckardGames
dionb wrote on 2020-09-15, 15:20:
Going to order a few 90Z.
Thank you all for the help.
I'll be back with news within a few days.
