First post, by Baoran
Looking at a compaq AT power supply from mid 90s or so it looks like pretty much normal AT power supply with same connectors and all. I have also seen people say that they are not standard AT power supplies in vogons forums. What is the actual difference between compaq and standard AT power supply? Would it be just matter of changing the order of wires in P1 and P2 motherboard power connectors to make it compatible or is there something else going on?
