First post, by 386SX
Hi,
trying to build a "modern" low-res (720p.. 1024x768..) game config with the components I got already, I was thinking to buy some cheap nobrand mobo and use one of these cpu adding some middle end modern GPU to that. What would you choose? I already have the mainboard for the E8600 but no double face DDR3 rams while I've the DDR3 single face rams for the other three but no mainboards... In addition I already have a compatible liquid cooling system if I'll have the need to boost some frequencies.
Thanks
