First post, by BetaC
I am making this thread for one simple purpose: I want to use components I already have in a build that really only requires adding a motherboard. I have a bunch of components that I have collected at random shops since I started really getting in to Retro stuff, and I am wanting to give some of them a more appropriate system to be in, and others a system to be in in the first place. On hand, I already have what's listed below as components that will definitely fit together:
  • Four 72 PIN RAM SIMMs, most likely totaling 32MB
  • Both a Pentium 100 and a Pentium MMX 166, and access to a 266 for cheap
  • Both an AWE64 and a YAMAHA OPL 3 Card
  • A minor collection of early 3D PCI cards, and a rather nice Matrox Millenium for 2D
  • A storage solution that is already set up and known to be working.
The only real issue I am having is figuring out what Motherboard I should be using for this. I am hoping to be able to find an ATX board that will work, but the majority of those on Ebay seem to either be Super Socket 7, or way too expensive for what they are. I am not opposed to SS7, mind you, I'm just hoping to keep things mostly before my Slot 1 Machine. The requirement for ATX is also not necessarily the biggest, either, if I would somehow be able to find a way to mount a Baby-AT board inside a modern case.
Reply 1 of 7, by waterbeesje
Most baby at boards will fit in a P3 time full ATX case, as the ISA/PCI slots will be on the right position. Above the board will be done empty space. Just make sure there are enough screw holes to put the spacers in place. You could create your own backplate from a blank one or just some aluminium tape and a piece of plastic.
Three power connector will be the biggest challenge here if you stick with pure S7. Lots of at Super7 boards allow for both at and ATX power connectors, along with the soft power button that comes with ATX form factor.
Super7 would actually be a good choice as the platform will support your CPU/graphics cards and allowed for future upgrades (larger hard drivers, AGP, even K6-3+) Performance may be pretty good compared to early S5/s7 chipsets. Just make sure it has 72p memory slots, or buy 64MB SDRAM for very cheap.
For super 7: clock the MMX to 83x3.5 for even better performance, most of them will do fine at just 2,7v or 2,8v 😀
Stuck at 10MHz...
Reply 2 of 7, by dionb
Firstly I'd avoid eBay for better deals - but what other options you have depend on local conditions and I'm not familiar with situation around ABQ.
Then regarding the requirements, most will be offered by pretty much anything with at least two ISA and three PCI slots - but one stands out:
access to a 266
Pentium MMX 'Tillamook' 266MHz and 300MHz CPUs are mobile-only CPUs with good support (including cache with unmodded CPUs) on desktop boards being very . So if you want that, that determines the shortlist of boards you can use.
See this topic for options:
Tillamook 266MHz and working L2 cache?
Quick summary:
- Tillamook can only boot on subset of motherboards, mainly due to very low voltage requirement (and some BIOSs getting knickers into a twist with unknown CPU)
- Only very, very few boards (mainly with SiS and Via chipsets from non-premium brands) fully support CPU with working cache without modification.
- Modification doesn't help boards to boot, but if they do boot it ensures L2 cache works.
- Modification is simple, two little bridges.
- Impact of no L2 cache is limited, usually less than 3% (frequently less than 1.5%) in benchmarks
So go for one of the (many) boards in that topic and you should be good. Best overall (but not common) is ECS P5SJ-A - it ticks all your boxes (ATX, non-"Super" So7, 4x SIMM, 3x ISA, 4x PCI - and supports Tillamook fully without modification)
Reply 3 of 7, by The Serpent Rider
If you drop Tillamook requirement, you can easily find ATX Socket 7 board from Intel. Although I don't know if they can or can't boot with Tillamook, at least Intel motherboard can boot with unknown CPUs like AMD K6.
Reply 4 of 7, by BetaC
The Serpent Rider wrote on 2020-10-15, 12:45:
dionb wrote on 2020-10-15, 09:31:
Firstly I'd avoid eBay for better deals - but what other options you have depend on local conditions and I'm not familiar with s […]
access to a 266
Sorry, I meant to say 233. I’m not looking to make something that fast, since my Deschutes P2 is unlocked and able to make that sort of speed easily.
And the situation here locally is “here’s a single shop that has some stuff, but the prices are way too high to justify buying most, and one recycler that has old stuff, but they don’t really sell.” It’s why I am looking through eBay.
Reply 5 of 7, by The Serpent Rider
In that case, go for ATX Intel motherboard. Some already have OPL3 Yamaha sound chip integrated.
Reply 6 of 7, by dionb
BetaC wrote on 2020-10-15, 16:42:
Ah, that massively reduces complexity. I'd agree with an Intel board (such as a TC430HX or ML430HX) or this morning I saw an Asus XP55T2P4 (same spec as ML430HX basically) selling for EUR 25 on Amibay. With EDO RAM the i430HX is the chipset to look for. Most are prosumer/SOHO boards, so quality and compatibility tend to be high.
What about Craigslist?
Reply 7 of 7, by BetaC
dionb wrote on 2020-10-15, 19:44:
It's usually a wasteland of toner cartridges and macbooks that are too highly priced to be worth looking at. Every once in a while you find something up there like an old Powercomputing Powerbase 180, but that's the exception. I will definitely be looking for a i430HX, thanks for the help guys.
