First post, by Camtheman
Anyone got any hot leads on one of these, preferably as cheap as possible?
Or a way to mod an ATX PSU with the missing pin to supplying -5v? (Soldering is fine by me)
And yes I do need the -5v, for a GUS Max 2.1
Early 90s: IBM PS/2 Server 95/A, Pentium 66, 16MB RAM, XGA-2, IBM SCSI Corvette, SCSI2SD, 3 Com EtherLink III MCA, Resound 2 AdLib MCA
Late 90s: Micron Millenia MXE, ABIT VH6-II, Coppermine 1ghz, 1024MB, GeForce 4 MX 440, GUS Max 2.1, 128GB SATA PNY SSD.
Reply 1 of 12, by kdr
Some of the ATX to AT adapters include a small linear regulator to generate the -5v rail, and that's an option to consider -- the current draw on -5v is minimal, so there's no need for anything fancy. (I believe they use something basic like a 7805 hooked up to the -12v rail?)
Otherwise go search for the absolute oldest ATX cases you can find... any motherboard that still included ISA slots would expect the ATX PSU to supply -5v.
I managed to find an ATX PSU with -5v by digging through a mountain of power supplies at one of my local e-waste recycling places. Most lacked -5v but there were a handful that had it. At least the presence/lack of -5v is clearly indicated on the PSU label.
Reply 2 of 12, by Camtheman
My mobo IS an ATX motherboard, only has the 20 pins instead of 24 though. So I couldn't use AT. Unless I get one of those and then convert it back to ATX 🤣
Reply 3 of 12, by Horun
Using the -12V line and a L7905 (T220 -5V Linear regulator IC) would work well. As for ATX supplies, most all new ones do not have -5v, you need to look for older ones but they most likely need re-capping.
An Enlight HPC-300-101 (300w ATX) has -5v, as do older Antec True Power 480 models...
Reply 5 of 12, by Errius
I went through my ATX PSUs a few years ago to check this. The following all have -5V:
Cortek LC-300
CWT CWT-350BDP
Delta DPS-260EB-2A
Enermax EG365P-VE(FM)
Enermax EG465P-VE(FM)
Enermax EG651P-VE(FMA)
Q-TEC Model 13492
Q-Tech QT-02350G
Sparkle FSP235-60GI
“Your mission is to attack and destroy the Apple Computer manufacturing plant. You are allotted 35 bombs and 60 lasers."
Reply 6 of 12, by adalbert
You can also solder LM2662 module to +5V line, it will turn it into -5V. It should provide 100mA. Here i soldered it directly to pico psu, I also added a protective Schottky diode on -5v output (it may drop the voltage a little as side effect), to minimize risk of passing positive voltage in case of failure.
Reply 7 of 12, by kolderman
Camtheman wrote on 2020-10-15, 23:03:
Not that crazy an idea given the lack of other viable options.
Reply 8 of 12, by Vynix
There are a few newly made industrial PSUs with a negative 5V rail, though these might be a bit tricky to find
Reply 9 of 12, by darry
Camtheman wrote on 2020-10-15, 22:16:
If you do not mind me asking, how did you come to the conclusion that a GUS MAX 2.1 requires -5V ? AFAIK, it does not .
According to https://upload.wikimedia.org/wikipedia/common … SA_Bus_pins.svg , -5V is on pin B5 of the ISA connector and if you look at a photo of a GUS MAX 2.1 , pin B5 is not connected to anything . https://i.imgur.com/wuLUwhf.jpg . Unless your card is different
Additionally no GUS cards are listed here : ISA Cards & Devices Requiring -5V
Reply 10 of 12, by Camtheman
darry wrote on 2020-10-16, 05:22:
If you do not mind me asking, how did you come to the conclusion that a GUS MAX 2.1 requires -5V ? AFAIK, it does not . […]
Well it turns out i'm a massive derp. I have a ESS AudioDrive 1868f, it has a bunch of missing pins on the ISA connector. The gus has all of them. I also didn't see the GUS appear in the BIOS initialization. It's not a PnP card, of course it won't show there. From all this I assumed it needed -5v to function.
I fiddled around with some IRQs and now the GUS works on the modern Corsair PSU.
Although I think the AudioDrive with the DreamBlaster X2 sounds better.
Reply 11 of 12, by darry
Camtheman wrote on 2020-11-27, 06:09:
Well it turns out i'm a massive derp. I have a ESS AudioDrive 1868f, it has a bunch of missing pins on the ISA connector. The gu […]
Glad that you got it working . IMHO, the GUS patchset is quite decent but an FX engine on the GUS would have helped the patchset really shine. The company that made that patchset has continued working on it for years. The most recent iteration in soundfont form (for Creative cards and SF2 compatible softsynths), is one of my favorites on my AWE64 and it is only 4MB in size! Here is some info, if you are curious : http://www.voicecrystal.com/services.htm
The X2 with Buran soundbanks is very good indeed and is better than MIDI on the GUS in nearly all cases, subjectively speaking. The X2 can't do tracker stuff, though, which is the main reason to have a GUS, IMHO . Unfortunately, not many games support the GUS in that way. For non gaming tracker based music playback, the software mixing and interpolation engine in Open Cubic Player is great and works with lots of ISA cards, including ESS based ones .
Reply 12 of 12, by digistorm
Yeah, well, you weren’t supposed to use MIDI anyway, the driver support was more meant as backward compatibility. You were supposed to upload your own sound effects to the RAM of the card. But in the end, MIDI was so well and firmly established that the whole idea of a Paula chip on steroids was a commercial failure and the GUS almost always was running in some kind of compromised compatibility mode and not in the native mode it was designed for 😐
