Reply 80 of 161, by Warlord
- l33t
I can try later but I don't think its going to work.
copy pasta from wiki
R100's pixel shaders
R100-based GPUs have forward-looking programmable shading capability in their pipelines; however, the chips are not flexible enough to support the Microsoft Direct3D specification for Pixel Shader 1.1. A forum post by an ATI engineer in 2001 clarified this:
...prior to the final release of DirectX 8.0, Microsoft decided that it was better to expose the RADEON's and GeForce{2}'s extended multitexture capabilities via the extensions to SetTextureStageState() instead of via the pixel shader interface. There are various practical technical reasons for this. Much of the same math that can be done with pixel shaders can be done via SetTextureStageState(), especially with the enhancements to SetTextureStageState() in DirectX 8.0. At the end of the day, this means that DirectX 8.0 exposes 99% of what the RADEON can do in its pixel pipe without adding the complexity of a "0.5" pixel shader interface.
Additionally, you have to understand that the phrase "shader" is an incredibly ambiguous graphics term. Basically, we hardware manufacturers started using the word "shader" a lot once we were able to do per-pixel dot products (i.e. the RADEON / GF generation of chips). Even earlier than that, "ATI_shader_op" was our multitexture OpenGL extension on Rage 128 (which was replaced by the multivendor EXT_texture_env_combine extension). Quake III has ".shader" files it uses to describe how materials are lit. These are just a few examples of the use of the word shader in the game industry (nevermind the movie production industry which uses many different types of shaders, including those used by Pixar's RenderMan).
With the final release of DirectX 8.0, the term "shader" has become more crystallized in that it is actually used in the interface that developers use to write their programs rather than just general "industry lingo." In DirectX 8.0, there are two versions of pixel shaders: 1.0 and 1.1. (Future releases of DirectX will have 2.0 shaders, 3.0 shaders and so on.) Because of what I stated earlier, RADEON doesn't support either of the pixel shader versions in DirectX 8.0. Some of you have tweaked the registry and gotten the driver to export a 1.0 pixel shader version number to 3DMark2001. This causes 3DMark2001 to think it can run certain tests. Surely, we shouldn't crash when you do this, but you are forcing the (leaked and/or unsupported) driver down a path it isn't intended to ever go. The chip doesn't support 1.0 or 1.1 pixel shaders, therefore you won't see correct rendering even if we don't crash. The fact that that registry key exists indicates that we did some experiments in the driver, not that we are half way done implementing pixel shaders on RADEON. DirectX 8.0's 1.0 and 1.1 pixel shaders are not supported by RADEON and never will be. The silicon just can't do what is required to support 1.0 or 1.1 shaders. This is also true of GeForce and GeForce2.
