First post, by Dougal
Hello I have this motherboard https://stason.org/TULARC/pc/motherboards/E/E … 86-UM-486V.html
It has a 486 DX2 66 Intel CPU
I put the ram 30 pins Simms (8 chip) 16mb (4mb each) which was working good in 386.
I power it on and it makes 3 beeps, long pause and then 3 beeps.
Please help ? Is the ram not compatible ?
Win 7 : Core2Quad 2.4Ghz, 4Gb Ram, Audigy 4 Pro
Win 98: Pentium III 600Mhz, 448MB Ram, Matrox Millenium DualHead 32MB, Sound Blaster 32, Roland MT-32
Win 98: Compaq Armada 7400 P2 333Mhz, 192MB Ram, ESS AudiDrive 1879 with Wavetable
Reply 1 of 2, by Deksor
In which bank did you put the sticks in ?
Can you shoot a nice photo (no cables in the way and not blurry) of your motherboard so I can add it here ? 😀 http://www.win3x.org/uh19/motherboard/show/2125
Reply 2 of 2, by computerguy08
Try booting it with a known working 4MB memory set in Bank 0 (w/1MB per stick). From what I can see, the board does not have dedicated jumper settings for DRAM config.
Also, make sure the modules are properly clipped in each socket.
