First post, by Intel486dx33
Hi, I am working on my Gateway Pentium-3 , 933mhz computer.
Its build date is 2001
It has an Intel motherboard with 815 chipset.
And AGP slot ( Not sure what speed )
I would like a good video card from about this time.
That will play the most games in good quality.
I am Running Win98se with SP3
I have installed a Sound Blaster live.
I have 512mb PC-133 ram.
Reply 1 of 6, by andrea
Some sort of R200 Radeon? I run a 8500@9100 on a Celeron 1100A@1466 and it seems well balanced. As you have a slower CPU a 9000 or 9200 will probably be fine.
Or a Geforce3.
Even the often derided Geforce4MX is not that bad in my opinion* (assuming we are talking about a DDR/128bit bus version). In my tests a MX440 performed the same as a GF2 Ti running at Ultra clocks.
*Of course you have to consider it as a fancy GF2 and not a true GF4
Reply 2 of 6, by BinaryDemon
I think Geforce3 would be an ideal match.
Check out DOSBox Distro:
https://sites.google.com/site/dosboxdistro/ [*]
a lightweight Linux distro (tinycore) which boots off a usb flash drive and goes straight to DOSBox.
Make your dos retrogaming experience portable!
Reply 4 of 6, by maximus
+1 for the GeForce2 GTS. Good match for the CPU, perfect compatibility for Windows 98 games, and great performance at 1024x768x32. GeForce2 Ti is also good if you're looking for a little extra speed. ForceWare 45.23 works well with these.
Nice system, by the way. Always been a fan of Gateways 👍
PCGames9505
Reply 5 of 6, by PC-Engineer
I have a similar system, first with a GF3 and now with an 8500. they are both good, compatible and fast cards with good focus for a system from 2001. The 8500 is a bit faster and has a bit better graphics quality and it is a bit more "special".
Epox 7KXA Slot A / Athlon 950MHz / Voodoo 5 5500 / PowerVR / 512 MB / AWE32 / SCSI - Windows 98SE
Reply 6 of 6, by chrisNova777
GeForce 2 would do the job
Or Ati rage 128 was also popular in that time or matrix g400
http://www.oldschooldaw.com | vintage PC/MAC MIDI/DAW | Asus mobo archive | Sound Modules | Vintage MIDI Interfaces
AM386DX40 | Asus VL/I-486SV2GX4 (486DX2-80) | GA586VX (p75) + r7000PCI | ABIT Be6 (pII-233) matroxG400 AGP
