First post, by mikedoubleu
Hi everyone,
I have been looking for a new power supply as I have caught the bug and started to build an Athlon XP 2800+ system (among others).
This would be because I tested the board and processor on a Cooler Master Masterwatt Lite 500, and the 5 Volt rail sagged to 4.52 Volts (eek)
I have happened past the following item on the CPC Farnell UK website...
https://cpc.farnell.com/ace/a-850br/ace-850w- … -fan/dp/CS31242
The specs for this power supply suggest it has a 38 Amp output on the 5 Volt rail, which I understand is almost unheard of in this day and age. I appreciate this is a basic/budget PSU, but I've gone ahead and placed an order for it. It surely cant be any worse than some of the really cheap PSUs I used years and years ago, back in the days when we bought cases from computer fairs and just used the PSU that came with it. Do you remember those things? They used to way 1/10th as much as a "proper" store bought PSU.
I thought I would share it here in case anybody has any interest or views on this PSU. I should have it in-hand in 3 days, and will be happy to share some information on it once it is plugged in and running the Athlon XP system.
Thanks
Mike
