First post, by Unite
I was working on my PC Chips M912 again this evening getting ready to drop a VLB IO card in there. The system was working 100% at the weekend but opened her up, installed the card, powered up to no display and lots of beeps. So removed the card powered on again but still no display. The beeps changed to 1 solid followed by 3 short. The weird thing is that the system continues to boot.
Specs:
M912 motherboard modded with 512kb of real cache.
Cyrix DX2-66
16MB of 72pin simms
S3 VLB graphics
generic crystal sound card
generic network card
PT607G IO card
The other VLB IO card I tried is an ST300ALI.
I've tried removing the sound card and network card, changed the system memory and even removed the 1mb ram expansion from the S3. None of this makes any difference. If I change out to another ISA video card (not vlb) the system boots without a beep but I get no display but I'm not sure if this card works or not.
Any ideas?
Reply 1 of 10, by Orkay
Have you made sure the card's contacts are fully inserted? I've had issues with VLB connections in the past, where the ISA side of the connection is all nice and tight in there while the VLB side may get loose at the end, possibly due to the motherboard not being held up to the very edge of it. Have you tried pulling a corner of the motherboard upward after connecting the VLB card to ensure they make full contact?
Reply 3 of 10, by ZombieMatrix
Did your system previously have a VLB card installed or was that something new you were using on your motherboard? Seems like I recall a few motherboards I've come across had settings to enable and disable the VL-bus.
Reply 5 of 10, by evasive
http://www.win3x.org/uh19/motherboard/show/572
JP16 close to get 1 wait state on the VLB, maybe the card doesn't like the bus speed that you are running at.
Start with ONLY the video card in there to see if you can make it give a picture again. I suppose you don't have any other monitor to test with either?
Reply 6 of 10, by Unite
Please delete this thread, I am an idiot of the highest proportions.
The VGA cable fell out of the back of the monitor and I didn't notice.
Just spent the last hour in a full panic and it was the comment about trying another monitor that made me see it.
Reply 7 of 10, by chrismeyer6
Hey these things happen to us all. I've forgotten to ether plug in the computer or flip the switch on the power supply and have a minor heart attack when the system won't turn on
Reply 8 of 10, by cyclone3d
None of us have eve had that happen before... nope, never.
Yamaha YMF7x4 Guide
Reply 9 of 10, by evasive
AAAAAAAAAAAAAAH the horror of being reminded to ones own stupid mistakes!!! In my what is it, 30 odd years interacting with computers I have knocked out cables, connectors, CPUs, memory, add-in cards and whatnot.
Trust me if I tell you: I have the utmost respect for you being honest about it.
And congrats on having a working M912 with real cache. That too.
