I have two SS7 boards from Soyo, both use Macronix MX28F1000 flash chips. In the photo that I posted the Macronix logo is visible, so probably a MX28F2000 if the bios image is 256KB. Was tempted to say that any 2mbit flash should work, but boards from that era often needed to write to the flash chip (ESCD or DMI data, I'm not so sure) so the chip needs to be compatible with the board otherwise a message along the lines of 'unknown flash chip' will greet you upon applying power.
majestyk wrote:The soldered jumper on the left is in a different position.
That^. And there could be differences in the passives soldered to the left of the chip (those below seem identical, although it's hard to tell for sure since the picture is so poor). If you find a still-active sale, maybe kindly ask the owner to provide a close-up of the area?
