First post, by lowlytech
Have an issue with an intel 850gb motherboard with it not reading 3.5"floppy disks. I couldn't get any floppy disks to read, so i swapped floppy drives, disks, cables, etc with no change. I pulled all the pci cards reset the CMOS to factory defaults, made sure MB had latest bios flashed with no change. Only after i pulled the geforce 3 card the floppy drive started working, so there is some kind of conflict. Anyone heard of something like this before? My only other thought is to update the geforce bios? But i am pretty uncomfortable or inexperienced with flashing video cards, on top of the whole floppy drive doesn't work when the card is installed. Any thoughts on a workaround?
I did test with another agp card, a nvidia geforce2 and didn't have the floppy read issue.
Reply 1 of 21, by Repo Man11
Assuming you haven't already, I would disable all unused hardware in the BIOS - serial ports, printer port, etc. anything to free up resources. If you're using an add in controller card, disable any unused IDE ports.
I've had similar situations with Via chipset Socket 7 motherboards.
Reply 2 of 21, by lowlytech
After disabling all serial, parallel, usb ports and downgrading the motherboard bios a few version it didn't change anything, i ended up finding a gf3.rom on philscomputerlab (thanks phil!). I had to override the bios but after the update from 3.20.00.10.2 -->> 3.20.00.12 this fixed the floppy issue for me.
Reply 3 of 21, by darry
lowlytech wrote on 2021-01-23, 06:25:
Wow! That is was a strange one. Thank you for sharing . To avoid issues, you might want to consider editing the video RAM timings and GPU clock in the 3.20.00.12 vBIOS to match those in your original BIOS .
Reply 4 of 21, by lowlytech
I hate to ask, but i have no idea how to modify clock speeds or what the original clock was. Is there a tool for this or do you have to modify with a hex editor? I see no brand name on the card, but i will see if i can get 3dmark test going and report back if there are graphic issues.
1.28 MiB
Reply 5 of 21, by Repo Man11
Congrats on solving that one! As I mentioned before, I've run into similar issues with Via chipset Socket 7 boards - no conflicts when using a GF2 MX, or a Radeon 9200, but suddenly the CDROM disappears when I installed a GF3 because of a resource conflict. But the MVP3 is known for that, where Intel chipsets are not.
Reply 6 of 21, by darry
lowlytech wrote on 2021-01-23, 13:40:
The tool I would try first is Nibitor, to at least compare the values . I assume you kept a backup copy of the old vBIOS .
See https://www.guru3d.com/files-details/nvidia-b … ad-nibitor.html
It goes almost without saying that you should be extra careful to avoid soft bricking or irreparably breaking your card . Either way, I disclaim any responsability .
Reply 7 of 21, by lowlytech
Thanks Darry for the link to the nibitor file. However when I open the one I downloaded from Phils site and the vbios i saved before the flash, both files say they can't find clockrates and are unsupported. I would love to know what the vendor of the old card was. Here are both the vBIOS files attached to this message. Currently have 3DMark2000 running on the machine to see if there is any instability.
    gf3roms.zip
    53.49 KiB
    33 downloads
Reply 8 of 21, by Repo Man11
If both BIOS were for a GeForce3, wouldn't the clock speeds be the same? https://www.techpowerup.com/gpu-specs/geforce3.c738
if you don't have a utility installed that tells you the clock speeds, Riva Tuner will do that. https://www.techspot.com/downloads/397-riva-tuner.html
Reply 9 of 21, by Horun
The GF3 TI 500 had a slightly faster clock of 240MHz core/250MHz RAM instead of 200Mhz/230Mhz but that is locked in the vBIOS somewhere and not adjustable AFAIK.
added: Just checked my Gainward GF3 TI 128Mb and it has a 200Mhz core/230Mhz memory (DDR 460Mhz) clock non-adjustable.
Reply 10 of 21, by Repo Man11
Horun wrote on 2021-01-23, 18:12:
Yes, the GeForce 3, GeForce 3 Ti 200, and the GeForce 3 Ti 500 had different clock speeds, but we seem to be going from GeForce 3 to GeForce 3 here.
Reply 11 of 21, by darry
Repo Man11 wrote on 2021-01-23, 18:24:
First, sorry about suggesting Nibitor, that only supports newer Geforce cards .
For a Geforce 3, you need Ray Adams' nVIDIA BIOS Editor :
RVBSETUP.EXE
617.36 KiB
63 downloads
(not that easy to find nowadays).
I took the liberty of comparing the 2 BIOSe ROMs and clocks seem the same, which is not all that surprising (though I seems to recall some pre-Ti Geforce 3 cards having higher than official clock, which is why I suggested checking in the first place, but I may be wrong about that) .
53.99 KiB
38.93 KiB
Reply 12 of 21, by lowlytech
Thanks for checking those BIOS files out for me and thanks for posting that editior. So the original card was a Visiontek. Anyone have a .12 bios for a visiontek gf3 or do you think this engineering version will be okay? Only thing i kinda don't like is now on POST i get a video card message saying this is an engineering sample and to not use it. However so far I haven't had any anomalies whatsoever.
The rivatuner says the gpu clock is running at 100mhz instead of 200. Do these gpus dynamically adjust their core clocks when under load?
1.19 MiB
Reply 13 of 21, by Repo Man11
I'm not sure if it's detecting the speed correctly - I'd use Powerstrip to double check. https://www.philscomputerlab.com/powerstrip.html
Reply 14 of 21, by darry
Repo Man11 wrote on 2021-01-23, 21:38:
I would also get at a bad detection .
As for engineering sample string, this modified BIOS should have that gone . It is based on your "new" one, but with all options matched to your old one, except the version and "OEM revision", which the BIOS editor does not seem to set successfully (when set to 2, it always reverts to 1, so I left it at 0 ).
22.72 KiB
gf3(new)_patched.zip
26.64 KiB
37 downloads
As always, although I have been diligent, I can't guarantee that this hasn't broken something, so be careful .
Reply 15 of 21, by darry
darry wrote on 2021-01-23, 23:22:
I would also get at a bad detection . […]
Oh, and according to your old BIOS, your Geforce 3 has a TV out (S-VIDEO and/or composite) and if you want that to keep working, you should probably use one of the BIOSes from here : http://www.x86-secret.com/Download/bios/GF3_3 … 20.00.12.00.zip
GF3_3.20.00.12.00.zip
102.77 KiB
39 downloads
based on the TV encoder chip on the card :
GF3BT.ROM --> Brooktree
GF3CH.ROM --> Chrontel
GF3PH.ROM --> Philips
SMGF3.ROM -->No TV out .
EDIT : Let me know if you want me to edit one of those for you (they all have "engineering sample" checked) .
Reply 16 of 21, by lowlytech
Wow, thank you so much Darry for all the bios patches and links. Yes this card has an svideo out i suppose would be nice to keep accessable. The chip is a conexant which has a sub id of bt869, so brooktree would be the correct one probably.
Thanks again for all the input and help with this card. A wonderful community and resource for sure. And yes the power strip util does report 200mhz for the core clock.
1.33 MiB
Reply 17 of 21, by darry
lowlytech wrote on 2021-01-24, 01:40:
Happy to help .
Here is a modified version based on GF3BT.ROM (for Brooktree/Conexant)
gf3(new)_bt_patched.zip
26.39 KiB
36 downloads
Reply 18 of 21, by Horun
darry wrote on 2021-01-24, 02:09:
Happy to help .
Here is a modified version based on GF3BT.ROM (for Brooktree/Conexant) gf3(new)_bt_patched.zip
Thanks ! I actually think have the same card (assuming OP has 180-p0050-0000-a09 silk screened on his) mine is a Visiontek 64MB from a Dell with bios 3.20.00.10.03, all green with same chips, same fan, same missing DVI port.
