First post, by manalog
Hi all, I am new to Vogons. I am a 23 years old guy really passionate about retrocomputers, especially the ones of 1990s. I got several of them, but now I’d like to ask you some suggestions about one of those, a Pentium 100 build.
Specs: Highscreen branded, PA-2000 motherboard, Pentium 100, 16 MB 72 pin DIMM, 1GB Quantum hard drive, S3 video card, Windows 95. It is a devilishly fast computer, really, it surprises all of my friends for how much it is fast. Soon (today perhaps) I’ll try to install a Creative CT3990 I found in the garage (was I lucky? Is it a good card?) and an Ethernet board. I am planning to order on ebay two 16mb modules, a 256kb cache dip module and a cf2ide adapter (planning to test other operating systems). Perhaps also a MPEG2 video decoder board.
Unfortunately this computer has a very weird problem, a problem for which I am doubtful if it has sense to plan all these upgrades or not. I remember when I was a kid (it was my granma’s computer) I played with it and I connected a PS/2 keyboard to it, a keyboard provided with a PS/2 to AT converter that was used at the time by my uncle on a very similar computer. That keyboard worked but, after that, a disaster has happened: this computer recognizes only that keyboard! I tried several working AT keyboards with no success, then a couple of PS/2 keyboards using that adapter and different adapters: nothing at all. I really cannot explain this thing. Now it is very problematic because I can use only that keyboard. The keyboard is an anonymous grey keyboard from early 2000s, it has no brand, only “Office Keyboard” on the top and “Smart keyboard” behind, “Made in China”, “Model No:Ez-9910”.
I have found in that same garage a mechanical IBM keyboard (perhaps the famous Model M, code is 1391404) with ps/2 connector: I tried it with several adapters on that computer but there is no way to get it working.
This is problematic because if the Chinese keyboard dies, then my Pentium will die with it. Moreover, I use this computer mainly for word processing (write stories) and, recently, I started a coding class and I really enjoy learning C on this computer. Now I am at the beginning, but I think very soon I will be able to try some mode 13h to write simple dos games (http://www.brackeen.com/vga/). I’d like to use the IBM keyboard, it is really a fantastic keyboard, but I can’t.
I don’t know if this can add some valuable info, but this computer has also another very strange “feature”: it is extremely sensitive to electrical (what, fields? I don’t know). That is, if there is something of “electric” happening on the same plug/room of the computer or I attach something to its ports, the buzzer will emit a sound. If I turn on the light in the room, sometime the buzzer buzzs and, if you don’t believe me I will try to replicate it and post a video, some days ago the top of weirdness happened: the computer was attached to its CRT Philips monitor via VGA Cable; my smartphone’s jack output was connected to Philips’ RCAs input for audio (I was listening to a coding lesson while programming on Borland 5 <3). PC, CRT and phone’s charger were all on the same plug. Well, if I moved the jack in the phone, then the buzzer made the sound. How is this possible? Bad insulation? Ground problems? Could it be related to the keyboard issue?
On this page: https://pcrebuilding.altervista.org/2/MOTHERB … D/SOCKET+5.html I have found several informations about the motherboard. Potentially, it has two connectors for PS/2 keyboard and mouse (CN1 and CN2), while now there is only AT keyboard (with the mentioned problem) and a very uncomfortable serial mouse. Moreover, I have found on the motherboard this table
JX1 AN6,7 RN5
EXT KB 2-3 ON OFF
INT KB 1-2 OFF ON
In the manual, JX1 is “Factory configured - do not alter”. I tried all the combinations but it didn’t solve the problem.
I am really frustrated by this issue. What could it be the cause? Could solder a ps/2 connector solve the issue? (but if I see the scheme it looks that at and ps/2 share the same contacts) Could I add an external controller in some way?
If you don’t understand something of my post tell it to me, I know my English is bad, sorry.
Thank you 😀
Reply 1 of 4, by quicknick
Hi, and welcome to the forums!
This is just my experience and I'm not ruling out other possible causes. Sometimes a fuse or inductor on the +5V line to the keyboard connector can fail to a high-resistance state. Different keyboards have different current draws, and can be more or less tolerant to out of spec supply voltage. Had that happen on a Abit KT7 that was donated to me, previous owner said the keyboard doesn't work, but for me it did. Puzzled, I made some measurements, and turned out that only around 3 volts reached the keyboard and the difference was lost on the failed inductor. So my keyboard was happy with 3 volts, but I guess most others would stop working at such a low voltage.
Reply 2 of 4, by manalog
Thanks so much for the answer, I think you figured out the cause.
I measured the output from the AT port (+5v and GND pin of course) and it was zero... so perhaps the chinese keyboard was able to work even without 5 volts and indeed the leds were always off when it was connected to that computer.
So I connected the CLK and DATA wires to the AT pin and +5V and -5v to the molex red and black cable. To do so, i modified and soldered wires in the PS/2-AT adapter. All connections were fine but unfortunaley I did a terrible mistake: to look better at the monitor I moved the keyboard and two wires short circuited, my guess is that CLK and DATA shorted because the power wires were insulated very well. Smoke and an horrible smell came out from the keyboard and of course it was dead even on another computer. I am a bit sad because it was the only keyboard I have used in the past 15 years...
As a matter of principle, I really wanted to solve the issue today so I figured out another solution: this time I used a PS/2 => USB connector, a USB dongle and an AT cable from a broken AT keyboard (it was shortcircuited probably due to leaking capacitors). In this way, I connected CLK and DATA to the mobo and the +5 and -5 to the usb connector plugged inside a phone charger.
This time I checked the connections several times with the multimeters and insulated everything with a lot of tape. The only keyboard left was the Model M and I really not wanted to fry it.
The keyboard still is not recognized but an important detail has changed. Before doing the external power thing, if I connected the Model M to the mobo it remained with led off and nothing happened if I pressed the key. Now leds are on (due to usb charger) and, the important thing, every time I press a key the motherboard emits a beep. So it is receiving some input from the keyboard but it is not recognizing it as a keyboard. Can I move forward at this point in some way or do I have to accept that today I've lost my keyboard, my Pentium I and all my retrocomputing projects?
EDIT:
It's working!!!
I have found this post on vogons: Keyboard error / no keyboard present
where a user reminds that there is often a continuity check between the outer ring of the connector and the keyboard. I have connected the outer ring (At => Usb insulation shield) but the crappy PS/2 to USB adapter no, so I put a small wire between the ps/2 connector and the USB connector and now it works perfectly and I am very happy, I hope I won't broke everything when moving the "thing" from a temporary to definitive state. Moreover, I want to get rid of the phone charger. Is it safe to connect the 5V directly to the Molex? I am really scared that the thing happened to the old keyboard could happen to the Model M too.
Reply 3 of 4, by dionb
Good work!
As for that PS/2 model M, no surprise that was problematic. IBM keyboards were great, but with great build quality came great power draw, a Model M draws about ten times as much as a contemporary Alps-based keyboard. So if any board is going not to work in a case like this, it's one of those monsters.
Reply 4 of 4, by Horun
manalog wrote on 2021-01-24, 20:21:
Yes ! The +5v on a Molex is the same as the +5v on the AT PSU cables where the KB power comes from on a proper working one.
Example: On one my Pentium board get a reading of ~0.4 ohm from the AT PSU +5v connections to the Keyboard +5v pin #5 on the AT KB connector, which is good cause only the little fuse is between the PSU line and the KB.
Too bad about the old KB getting shorted. It is getting harder to find any decent PS/2 KB's in my area, No true AT found in nearly a year. Last ones found were two HP black/silver (kb-0316) ps2 for $3 each and they work well for test KB's.
