iFXBR wrote on 2021-01-25, 02:21:
Game setup maybe? Also, check your Sound Blaster card version. Depending on model, you have to install MS-DOS drivers prior to run the game. Old Sound Blaster models offers jumpers to set IRQ and DMA addresses. Default SB config is IRQ5 DMA220.
It was something simple . IN game setup. Sorry im not great with retro PCs. Still trying to figure out the best autoexec and config sys so I have enough memory for games and be able to run the cdrom and mouse and sound...
Having some other issues unfortunately. My 5.25 floppy drive is not configured properly in the bios which i think is causing some issues. When istalling games under DOS, when inserting the second disk the drive will say there is nothing there. Installing the same game in windows works fine.
I have to get into the BIOS, but my keyboard does not register the control and alt keys and i have to press cntrl+alt+esc ...
Lastly, im running games that should run well on the system but they go slow. Maybe I need a better video card?
