Doornkaat wrote on 2021-02-15, 13:17:
To my knowledge +3.3V isn't present on the P5A PCI slots. Could it be the bridge needs that and you have to hack your board to supply the voltage?
Could it be that simple ? I'll test it when I get the chance. Thanks !
edit: I'm gonna say you're right without testing it. I've looked at the bridge and ... All the 5V lines are connected to each other and a few caps, though nothing visible goes to any chip that might be a regulator.
So I took out the multimeter and measured around and... aside from the 5V lines in the back being connected together, and the 5V lines on the front being connected together with some caps. They aren't connected to anything else. So yep, this board needs a 3V3 line on the pci bus to function.
Do not ask Why !
