Reply 22 of 30, by Sphere478
We have a request from the discord discussion: try to get xp or windows 7 on it :p
Max out the ram.
With maxed ram which would be 128mb? Maybe 256mb with simm stackers? Or whatever the chipset maxed out at it might be possible?
There is a working way to get 7 setup to run on a system with 96-384mb of ram which usually won’t even run. It’s a hex edit of the iso file.
But I think you will not be able to load 7 setup because of lack of acpi support so that will be big issue. XP will likely work though.
🖥Craziest socket 7 build on a 430tx chipset
🖥Dual socket 7 build
Reply 24 of 30, by Sphere478
pshipkov wrote on 2021-02-22, 02:27:
This is a hybrid 386/486 chipset, so anything that ever ran on 486 will work.
XP will be too much trouble. NT4 may be a better fit.
eh, but no one will be impressed with NT
I mean sure, for actually using the thing prob go for a 9x/NT OS. But for SCIENCE!!!, see if XP will cram onto it! Mad computer scientists everywhere are watching with great interest!
Reply 26 of 30, by mpe
pshipkov wrote on 2021-02-21, 16:50:
_
Thanks. Your AMI BIOS works fine. Haven't noticed any stability/performance difference compared to Mr. BIOS but it is good to have the version that is original for the motherboard.
Blog|NexGen 586|S4
Reply 27 of 30, by Eep386
Just for fun, what happens if you pull the one 32Kx8 TAG chip, and replace it with two 8Kx8 chips, one in the empty socket next to it? Or maybe try putting a second 32Kx8 in that empty socket?
I am wondering if that will enable write-back caching mode on that board. If it works test it with Cachechk.
I also found the TH'99 page for that board: https://stason.org/TULARC/pc/motherboards/U/U … 86WB-CACHE.html
Reply 29 of 30, by mpe
The manual says either single 32x8k or two 8x8k when using 256k. But will try to use two chips.
Write-back cache L2 is enabled (confirmed).
The fastest timing I could use is 3-2-2-2.
Surprisingly, disabling L2 cache delivers almost double memory throughput which is likely better for application performance (unless running 386 where any cache helps a lot).
Will try to see if it can be tweaked.
Blog|NexGen 586|S4
Reply 30 of 30, by Eep386
Try using write-through cache in BIOS.
