Reply 20 of 30, by Doornkaat
megatron-uk wrote on 2021-04-16, 08:45:
If you consider the relatively modern terminology of using base-10, yes, but the traditional computing science units that I was […]
Doornkaat wrote on 2021-04-16, 08:00:
I'm getting more confused. Asking those who are more knowledgeable if my understanding of the terminology is correct: kilobyte = […]
kilobyte = kB (or kByte)
kilobit = kb (or kbit)
megabyte = MB (or MByte)
megabit = Mb (or Mbit)
1 megabyte = 1000 kilobyte = 8 megabit = 8000 kilobit
1 megabit = 1000 kilobit = 0,125 megabyte = 125 kilobyte
If you consider the relatively modern terminology of using base-10, yes, but the traditional computing science units that I was taught some 30 years ago are:
1 Megabyte = 1024 Kilobytes
The use of base-10, rather than base-8 numbers is a relatively new concept - you'll see some references to SI-sounding unit names like kibibit and kibibyte and mebibit and mebibyte. These terms didn't exist when most of us oldies were going through school/college/university.
It's why your 2TB hard drive is actually 1.85TB in reality - disk drive manufacturers always use the base-10 version to make it seem larger.
That's why gigabit (1000 megabit) ethernet has a maximum transfer rate of ~125 megabytes/sec (1000 / 8 = 125).
Oh yes, I knew about this. It doesn't help my general confusion about the units that the kibi- is abbreviated with a capital K ("Kibit"). 😅
Reply 21 of 30, by Sphere478
Doornkaat wrote on 2021-04-16, 07:07:
I'm reading this as 4MByte/s, right?
yes
Oetker wrote on 2021-04-16, 08:00:
Sphere478 wrote on 2021-04-16, 06:16:
sitting around 4 mb/sec with intel pro gt and killer nic. the killer seems to be a few tenths of a mb/sec faster though
So the realtek was faster for you?
it appears so but that doesn't sound right. I need to re run the test and be sure all contributing factors are the same.
I'll post a confirmation if I do re run the test.
Sphere's PCB projects.
Reply 22 of 30, by megatron-uk
I'm surprised you are not able to achieve the full bandwidth of a fast ethernet connection on a Pentium 133.
What is your testing routine?
https://www.target-earth.net
Reply 23 of 30, by GigAHerZ
@megatron-uk, that's wrong today. There are different SI prefixes for base-10 and base-2 units.
https://en.wikipedia.org/wiki/Binary_prefix
Kilo- is always 1000, Mega- is always 1 000 000, etc.
This standard exists since 1998, so already over 2 decades.
One of the biggest rule-braker today is Windows operating system, that shows 2-based numbers, yet puts 10-based units behind that number.
Reply 24 of 30, by megatron-uk
GigAHerZ wrote on 2021-04-21, 07:15:
@megatron-uk, that's wrong today. There are different SI prefixes for base-10 and base-2 units. […]
I know 😀
30 years ago, that wasn't what we were taught. As far as I'm concerned, my Computer Science degree was in units that predate the renaming of those prefixes, and I'll continue using them until I die 😁
Reply 25 of 30, by GigAHerZ
@megatron, i assume you will not touch any programming languages beside basic and fortran, either. 😀
Btw, this forum is using UTF-8 charset, which also didn't exist back then, so i believe you've forced your browser to ASCII encoding, right?
And by all means, no more than 8 bits for datapaths!
What i want to say is that world is advancing and it's more advantageous to adapt to it, than to be a "dinosaur".
Reply 26 of 30, by megatron-uk
GigAHerZ wrote on 2021-04-21, 08:10:
Nope, that's me: dinosaur.
Well, my kids would have me believe it.
Reply 27 of 30, by Sphere478
megatron-uk wrote on 2021-04-21, 07:10:
dual pentium mmx 233
speed measured by second windows 10 modern computer over the network copying large file to dual pentium
Reply 28 of 30, by megatron-uk
I suspect you would get a truer representative of the throughput if the cards if you used iperf or similar.
When you say "large" files... 1mb, 10? 100?
You also need to run the test in both directions, otherwise you are limiting your test to how fast the IO subsystem can write the data to disk. Running it the other way should at least shoe you if you are disk write/read limited as well as or instead of NIC limited.
Reply 29 of 30, by megatron-uk
Just my 2p/2c or whatever, but a dual 233 should be able to saturate a fast ethernet link. You've got a bottleneck somewhere, or your cards/switch or whatever are operating in half duplex mode.
Reply 30 of 30, by Sphere478
the network wasn't cooperating when I tried it which is it's usual state actually. I think i could only see the shared folder from the windows 10 computer. that or the windows xp computer didn't show mb/sec
iperf?
one of these days I may try the test again. busy with other stuff.
