First post, by Dave Bursik
Hi,
I bought Compaq Armada 7800 (6300/T/8000/V/0/3).
Anybody know how to get a BIOS ?
Thanks Dave
Hi,
Thanks Dave
Supposedly hitting F10 after turning on the computer gets you into BIOS.
Edit: Also some websites say you'll need a setup disk.
Doornkaat wrote on 2021-03-01, 16:05:Supposedly hitting F10 after turning on the computer gets you into BIOS.
Thanks. F10 doesnt work 🙁
Anybody has a "SETUP DISK" for a BIOS ?
f10 works if you have a special compaq bios partition. without that, you'll need a boot bios disk/setup program
even without the bios disk, you should be able to boot into the computer.
Here is your laptop:
https://web.archive.org/web/19990828111155/ht … s/us/2_123.html
Look for the softpaq numbers and search for them on Google to download.
vetz wrote on 2021-03-02, 09:45:Here is your laptop:
https://web.archive.org/web/19990828111155/ht … s/us/2_123.htmlLook for the softpaq numbers and search for them on Google to download.
Hi, thanks a lot for your help!
Dave
Hi,
I upgraded the BIOS, but F10 still not working.
Btw. After I upgraded the BIOS, laptop starts well. But after 2 minutes LCD backlight stop working. May be this issue related to a BIOS upgrade?
The BIOS (RomPAQ) upgrade itself won't help. Did you install this SOFTPAQ (PC Diagnostics) ? https://web.archive.org/web/19991010062543/ht … tware/1237.html
vetz wrote on 2021-03-06, 16:26:The BIOS (RomPAQ) upgrade itself won't help. Did you install this SOFTPAQ (PC Diagnostics) ? https://web.archive.org/web/19991010062543/ht … tware/1237.html
Not yet, I will try it.
Btw. I downgraded the BIOS on the previous version. But problem with LCD backlight is not solved.
