First post, by Dave Bursik
I bought Compaq Armada 7800 (6300/T/8000/V/0/3).
Anybody know how to get a BIOS ?
Thanks Dave
Reply 2 of 10, by Dave Bursik
Doornkaat wrote on 2021-03-01, 16:05:
Supposedly hitting F10 after turning on the computer gets you into BIOS.
Edit: Also some websites say you'll need a setup disk.
Thanks. F10 doesnt work 🙁
Reply 4 of 10, by kleung21
f10 works if you have a special compaq bios partition. without that, you'll need a boot bios disk/setup program
even without the bios disk, you should be able to boot into the computer.
Reply 5 of 10, by vetz
Here is your laptop:
https://web.archive.org/web/19990828111155/ht … s/us/2_123.html
Look for the softpaq numbers and search for them on Google to download.
Reply 6 of 10, by Dave Bursik
vetz wrote on 2021-03-02, 09:45:
Hi, thanks a lot for your help!
Dave
Reply 7 of 10, by Dave Bursik
I upgraded the BIOS, but F10 still not working.
Btw. After I upgraded the BIOS, laptop starts well. But after 2 minutes LCD backlight stop working. May be this issue related to a BIOS upgrade?
Reply 8 of 10, by vetz
The BIOS (RomPAQ) upgrade itself won't help. Did you install this SOFTPAQ (PC Diagnostics) ? https://web.archive.org/web/19991010062543/ht … tware/1237.html
Reply 9 of 10, by Dave Bursik
vetz wrote on 2021-03-06, 16:26:
Not yet, I will try it.
Btw. I downgraded the BIOS on the previous version. But problem with LCD backlight is not solved.
Reply 10 of 10, by Delphis1982
Yes, I know, this thread is a bit old, but the answer fits the question.
The problem is, you have to create a separate primary (!) partition on your hard drive (OK, not by YOURSELF, but the setup diskette will create it).
I suggest to use partition magic (not parted magic) to move the actual partition a little bit to the "right" and leave at least 32mb of free space (unpartitioned).
The partition created by the setup diskette is about 6-8mb, it has some kind of FAT12, but with a different partition ID (Partition type 12).
You will need two Softpaqs (added as attachments in my post):
SP12906 (The Diagnostics Diskette),
SP9962 (The Setup Diskette).
Be aware, that you will need a running Windows 3.1-98 System (no NT series) to create the needed floppies (it uses QRST5 to write the floppies).
Then you first boot from the Compaq Armada Setup Diskette, to create the partition needed to contain the Diagnostics tools (and the BIOS-Setup).
While creating the partition you will be asked to insert the Compaq Armada Diagnostics Diskette.
At last you insert the Setup Diskette again to finish the setup.
As a final step you could use partition magic again to move the Windows partition back to fit near the new created partition (mark the Windows partition as active).
Now you can use F10 to enter BIOS Setup.
If you press F10, the Armada will reboot and you can see booting an operating system similar to DOS and after that it will load the BIOS Setup.
It's some kind of Windows 3.1 look with mouse support.
