First post, by pentiumspeed
The specs is detailed in this PDF: http://pdfstream.manualsonline.com/0/0bf63e18 … f1c4b1ce48b.pdf
Manufactured in July 2007.
It can do 70hz on lowest resolutions 640x350 and 720x400; also 640x480 can do 60Hz & 75Hz. Also 800x600 at either 60Hz and 75Hz
It has Sync on Green too if needed.
Was trying to find a monitor that can do vintage gaming especially DOS.
Anything else?
Great Northern aka Canada.
