First post, by Scythifuge
Greetings,
I have been moving forward with my Ultimate 1980-1999 Pentium III build with the commercial version of moslo. It has an AWE32, SCC-1, SB Live!, a Voodoo 2, and a Voodoo 3. I am trying to make sense of rloew's TBPlus package in an attempt to connect 1 or 2 1 TB drives (Asus P2B.) My hope is to find a Voodoo 1, a second Voodoo 2, and replace the Voodoo 3 with a V5 55oo, and replace the P3 550 with a slocket with a Tualatin (if possible) for the ultimate retro gaming experience. I even found a beige desktop case that is the exact same as the black desktop cases I have (7107BB, though the beige is rebranded as Antec but is clearly a compucase/HEC.) I aslo found a brand new, still-in-the-box 19" KDS monitor and an HP LP2065 (and I will eventually experiment with projectors, as long as I can make the screen small in the 25"-30" range.)
If I can find the V1 and the 2nd V2, I will have absolutely no slots left for a SATA adapter (so I am using sata/ide adapters,) modems, or NICs. I know I can get a neat external modem that I can use in DOS/Win 3.x/Win9x, but I am not having much luck finding a serial port option for giving this box networking capabilities. I will probably use the modem more than a LAN option as I won't surf the net much and can use the USB ports to transfer files, and I'll use the modem to play around with BBS software. However, I want this box to have every capability that I can think of. Hell, it even has a 5.25 floppy drive.
What are options for using ports to provide networking capabilities across the three OS I am using? Thanks!
Scythifuge
