First post, by weldum
- Member
hi, i have one of these vortex86sx based thin clients
vortex86sx 366mhz
128mb
xgi volari z9s 16mb
rdc r3060-something fast ethernet nic
no serial or ps2 for mouse
usb not detected in os (non-standard implementation maybe)
i'm trying to get it to play nice with windows 98se, for now vga works with scitech univbe driver, and now i'll try a different, free driver
the nic works perfect with a packet driver and with mtcp in dos, need to try the ndis2 driver with windows 98
as there are no chipset or specific drivers for this thing, compatibility is very bad, the "hard disk" (a compact flash mounted natively as an ide device) doesn't support dma and most hardware doesn't get detected (like usb and nic)
it would be ideal to get vga working natively with some sort of driver, i don't know if there's a way to get wdm display drivers from xp/2000 to work in 98se
for now, i need to get working the mouse, i'm using a standard usb mouse, but it only works in "legacy usb" mode under dos and get detected as a ps2 mouse by cutemouse.
using breadbox ensemble, i can't get it to work by using the "logitech ps2 mouse" driver but i suspect that this gui uses bios access to enable it.
under 98se it works in the first phase of the setup and never gets recognized again.
is there a way to get "bios mouse" support in 98se? thanks
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
