First post, by whitepawn
- Newbie
Hi,
I needed XTIDE for one of my socket 3 system (Has only ISA Slots) so decided to experiment with it.Here is my steps and problem:
I programmed an intel flash chip P28F001-BXT with my socket 7 motherboard with hotflash method.(I have used uniflash program to write 128KB file.I put xtide_atl to file and filled remaining bits with 00.)
After programming chip i used my 3com pci card to test it on my socket 7 mobo.Configured card with 3com program and set bios address to D000.XTIDE loaded perfectly and booted system fine.So far everything works fine but i needed ISA slot version of this network card XTIDE for my socket 3 system so i moved on to ISA card.
I removed flash chip and installed to intel (ISA) network card.Tried to setup it with SOFTSET2(Intel config program) and set it to D400.But XTIDE is not loading anyhow on same system.(Socket7)
Also tried with other address settings but no luck so far.Tested network card seems ok except it says "no flash" and i assume this is normal behavior or should it say checksum error or something.
Could anyone have any idea?
