First post, by Klaatu
Hi all I've recently been restoring old sgi dual PIII with tyan thunder 2500 board with win98/xp dualboot and have run into an issue with usb support in xp which has left me stumped.
I've done quite a bit of research concerning bios, power issues etc and nothing seems to be working. I am starting to think this could be a driver issue but cannot find any drivers for the motherboard (there are dead links to the on board scsi controller and audio device on the net but I cant find the chipset drivers etc). So I guess one question is does anyone have the complete driver set for this board... I have checked the driver library? It is the s1867 one with serverworks serverset iii he chipset.
The usb issue is strange... I did the 98 install first which went smoothly and 98 installs the following usb drivers:
"Standard OpenHCl usb host controller"
"USB root hub"
The usb (1.1) ports work fine under 98.
During the xp install the installer kept hanging after loading drivers so I basically disabled everything in the bios that I didnt think was necessary for the install... (network, scsi, usb, audio, floppy) I think it was. This allowed the install to complete.
After successful login, I rebooted and reset bios to defaults, logged into xp again, and let xp install the extra drivers.
This all looks good but the usb ports do not work... they power up the mouse, but when xp trys to install the usb device it produces the "usb device not recognized error" and the devices remain with yellow question marks next to them under the usb controller tab.
Interestingly xp didnt install the same driver as 98 for the host controller and has instead installed a more appropriate looking host driver:
"Serverworks serverset PCI to USB host controller" or something like that (not at machine at moment!)
If I select update driver the standard OpenHCl controller is also available so I tried selecting that driver rather than the serverset one but this did not fix the issue. I've also tried turning off power option for the usb controller and checked bios setting... all the pci options are set to enabled and default IRQ / timing settings.
I have also tried booting with acpi enabled and disabled neither of which fixes problem.
I'm now wondering if installing with acpi disabled could have screwed the install or something?
