First post, by Scott8bit
Recently upgraded board... stupidly forgot to realise i dont have any other mice only PS2, but MB only has AT 5pin,
I bought a converter for keyboard (https://www.ebay.co.uk/itm/PS2-Keyboard-to-AT … le/192948078214) and that works
great, but I totally forgot about the mouse, so question, would a PS2 splitter work on that adapter too? has anyone any experience with that?
another question, has anyone tried one of these PS2 PCI adapters?
https://www.ebay.co.uk/itm/Connectland-070901 … aoAAOSwff1fo9uq
my question is would DOS/Win3.1 detect PS2 without drivers? i wouldnt normally care and just buy a serial mouse but im loving my retro microsoft PS2 mouse
thanks in advance
Reply 1 of 2, by Horun
No you cannot run a PS2 mouse thru an AT keyboard connector under any method, the keyboard controller will not know what to do with it.
Some PS2 mice are serial compatible ,but many are not, and you can use a serial to ps2 adapter.
What make/model is the mouse ?
All mice (serial or ps2 or USB) require a driver whether DOS, Windows or whatever OS.
Reply 2 of 2, by Scott8bit
Horun wrote on 2021-03-18, 23:09:
No you cannot run a PS2 mouse thru an AT keyboard connector under any method, the keyboard controller will not know what to do […]
thanks again for your reply! the mouse is the Intelimouse v1.2 (ball inside) , good shout with the serial mouse converter.
never even thought about that!
I do have about 10 mice actually that i bulk bought a while ago (all ps2) so I should be able to get one of them to work with the converter idea,
thanks agan for your advise
