First post, by thegenerallee86
to be my Main Windows XP retro Gaming rig with 2.66Ghz Pentium 4 512MB DDR Ram, No HDD though which I already ordered an 80GB one for it and was also wondering anyone have any idea what the NUE means?
Reply 1 of 35, by pentiumspeed
IBM and lenovo base theirs by 4 digits for model type followed by a dash then 3 characters for pre-configuration of options that were ordered in. If anyone have -CTO, that's custom configuration during order purchases.
Cheers,
Great Northern aka Canada.
Reply 2 of 35, by feltel
With a little bit of luck you can check the original configuration of your machine at https://psref.lenovo.com/WithdrawnBook. IBM and Lenovo were very strict in documenting every possible configuration in their Product Specification Reference.
Reply 3 of 35, by thegenerallee86
feltel wrote on 2021-03-25, 07:15:
That helped a little I know from where I bought it is Pentium 4 2.66Ghz 512MB DDR Ram but it didn't come with HDD and the ram is mismatched with 512MB x 2 256 MB sticks one is 266mhz and one is 333Mhz which sucks, the motherboard P/N is 32P2992 and it came with Windows XP Professional cause it has the Key Code sticker on the side. Still can't figure out if it can be maxed out at 1GB or 2GB Ram.
Reply 4 of 35, by red-ray
thegenerallee86 wrote on 2021-03-25, 11:15:
How many DIMM slots does the motherboard have? I suspect at least 2GB and probably 4GB if it has 4 slots, I would use SIV ask it.
What chipset does it have?, if you don't know check [PCI Bus].
I think it's got an 82845G which supports a 512-Mb density so such as 2/4 x https://www.ebay.co.uk/itm/174347556738 should be fine.
Reply 5 of 35, by thegenerallee86
red-ray wrote on 2021-03-25, 13:59:
How many DIMM slots does the motherboard have? I suspect at least 2GB and probably 4GB if it has 4 slots, I would use SIV ask it […]
I know it has 2 Memory slots and the chipset should be intel 845G and I am installing Windows 2000 Professional and then going to try and install Windows XP Professional when it is done installing 2000 Professional.
Reply 6 of 35, by thegenerallee86
I just bought 2x1GB sticks of PC2100 DDR RAM for it to Max out the ram and now am looking to max the cpu out as well! I also want to find out what is the best low profile Graphics card AGP or PCI for it because it is half hight pci expansions slots in the back? I am looking to make this my Retro gaming PC for Windows XP Games!
Reply 8 of 35, by thegenerallee86
red-ray wrote on 2021-03-27, 14:57:
Is that for XP as well? because I am going to use this for my XP Games Gaming rig?
Reply 9 of 35, by red-ray
thegenerallee86 wrote on 2021-03-27, 15:01:
Of course it's XP and also 2000, 2003, Vista, 7 and 8. Check https://www.nvidia.com/Download/Find.aspx?lang=en-us to see which drivers are available.
Reply 10 of 35, by thegenerallee86
Ok cool just wanted to make sure I will be getting 2 of them one for my IBM 300PL and one for my NetVista 8303 Black the one that has XP professional on it.
Reply 11 of 35, by thegenerallee86
red-ray wrote on 2021-03-27, 15:27:
Looks like I'll have to find a bigger power supply to fit in it cause the one in there is only 160 watts!
Reply 12 of 35, by thegenerallee86
Ok I found 2 power supplies that look like they'll be my best options:
SilverStone TX300:
https://www.amazon.com/SilverStone-Technology … 17363138&sr=8-4
or this Apevia TFX-AP300W:
https://www.amazon.com/Apevia-TFX-AP300W-Stan … 17363138&sr=8-3
Reply 13 of 35, by chrismeyer6
I'd personally go with the Silverstone one. I use their power supplies in most of my builds and with the 50 or so I've used I've never had any issues with them.
Reply 14 of 35, by thegenerallee86
chrismeyer6 wrote on 2021-04-02, 12:55:
Just purchased the Silverstone one and now on to buying a dedicated graphics card for which I think I am going to go with the GeForce 6200 Half Height because this Prebuilt is SFF case!
Reply 15 of 35, by chrismeyer6
Good their good quality units. The 6200 8s a good card for a low power small system. I remember seeing some 6600s that were half height as well that wouldn't be bad to look for as well.
Reply 18 of 35, by thegenerallee86
chrismeyer6 wrote on 2021-04-04, 00:41:
Nice that card should serve you well in that system.
I am also getting the PCI one for my IBM 300PL 6862 Windows 9x Gaming machine as well.
Reply 19 of 35, by chrismeyer6
Nice. I used one for quite awhile in one of my dual P3 500 machines and it performed quite well for the games I played on that system. It may not be a power house card but it runs very cool and had really good compatibility with older directX and open Gl games.
